1 - 20 of 94 Posts
Drew03Accord
Atlanta
Just discovered this tonight. Simple and quick as can be... no turkey baster or hose disconnects needed and you don't even need a helper. All you need is a cup.
The power steering reservoir is mounted on a metal bracket and can be removed by simply pulling up on the canister.
With the cap in place, grab the reservoir around the rim and pull straight upwards until it's off the bracket. With hoses still attached, move it to the front of car, towards the radiator. Get the cup ready, then tip the reservoir and remove the cap, letting it drain into the cup. There is enough length on the hoses where you can completely invert the canister and empty it. Add new fluid and replace the cap. Leave the reservoir hanging then go start the car and turn the steering wheel lock to lock a few times. Shut off car, and empty it again (the fluid flows at a high rate so it mixes in quickly). Repeat as few times, then snake the reservoir back into it's home and push it back down on the bracket. If you have very dirty fluid, do this 3X then do a single drain n fill every year (or two) after. That should keep the fluid nice and healthy. Additional benefits of this method... no starvation or running pump dry, no air in the system and no mess.
Another piece of info you might find valuable. The reservoir has a mesh filter near the bottom which is there to filter out particles before they go into the intake hose. That's the large hose at the very bottom of the canister. When empty, you can shine a light down into the bottom of the reservoir. The black thing you see is the screen and you can verify by gently poking it with a screwdriver, just don't punch through. If this screen gets dirty and clogs, it impedes flow of the PS fluid and causes the dead spots you feel when turning the wheel along with groaning. Eventually the starvation damages the pump. This is why some have changed their PS pump and O-ring only to find that it didn't help much. The solution is to replace the reservoir or remove it and clean the filter with some type of spray or soaking in solution. Of course, allow it to fully dry before replacing. I suggest just replacing but I know how cash can be tight.
Hope this helps someone. ....Drew.....
Moderator edit: Please see post #64 in this thread for more pictures!
Thanks for this! I just did this today. My fluid was extremely dark. I couldn't figure out the best way to tip the canister. I ended up going under the ac hose and tipped it to the right in front of the radiator. It seemed like that might not have been the best way. I really don't want to crack these hoses. Is there a better way to maneuver it?
Discussion starter · #7 ·
Sounds about right. Any way that allows you to empty it is fine. I was able to do it without stressing the hoses too much. I guess if the hoses were brittle, I'd find another way but mine are pretty supple.
Just thought I'd add 7th gen PS fluid capacity to this thread. Princess deserves the credit as I copied this from an old thread of hers.
System capacity:
1.1 L (1.16 US.qt) at disassembly
Reservoir capacity:
0.4 L (0.42 US.qt)
No prob. If you wanna be cheap, save the last batch you pour out in a bottle for future top offs. It's a lot cleaner than what you started with.
Tried to do it this way over the weekend but could not tip the reservoir enough and have room to empty it out. I ended up just doing it the turkey baster way, doing 3 drain and fills. Its definitely messy that way but I made sure I had a rag spread out under and around the reservoir. Took care of the O-ring a couple of days earlier also. Unfortunately its not cold anymore and the power steering noise was only happening on extremely cold mornings so I probably will not know if it worked or not until next year :)
Discussion starter · #12 ·
i4 or V6?
I just got all new PS fluid for free from Honda when I went in for the V6 recall :thmsup: Hook, line, sinker...done.
You've got a good dealer. Mine tried to upsell a flush...
I just replaced my PS pump because it sprung a leak. I paid $95 dollars from autozone. It's a rebuilt OEM unit.
I sh1T you not. The dealer wanted $680 for this job
Yea, could've been luck o' the draw lol I have 2 local ones and just happened to choose the one over the other. The guy says "Mr ******* why don't I have you in my system?" I said "Are you kidding? It's a Honda. She hasn't needed service" bahahaha :D So they were probably trying to win me over to "return" for more service on later dates by giving me a full flush. Hey, I do 99% of my own maintenance, so no complaints here!
i4 or V6?
V6
Same with mine. They also were quoting me $30 to change out the O-ring. I know they have to make money and I'm sure dealers find plenty of people to screw over, but I don't get why they don't use some common sense and not try to BS everyone that walks through the door. I had an issue with my battery this weekend and had to get it replaced under warranty. This same dealer wanted to charge me $40ish to get it installed. I again said how replacing a battery is a 5 minute job and I'll just do it myself and he actually mentioned that they'll have to reset the radio codes too...lol. I had to just laugh that off and just ended up going to another dealer who swapped it out for me and let me install myself. It actually took calls to 4 different dealers before I found someone who would let me do that so they all mostly work the same way.
If you turkey basted all of the fluid from the reservoir in the parking lot before handing it over them, I think they would have no choice but to give you some free juice =)
Lol...thats not a bad idea...but I wonder if you may damage your pump driving it there without any fluid.
1 - 20 of 94 Posts
