Hello,
I got 1996 accord LX used car last year. Took it to dealer for oil/filter change. They told me Brake and power steering fluid is dirty and need to be replaced.
1. How do I do brake and P/S fluid flush and drain? Do I need to buy Honda OEM fluid from dealer?
2. Also radiator fan is running if the car is driven for long time and it keep running after car is switch off then shut off after 20-30 min or so. I checked the coolant and reserve take is empty. There is green coolant in radiator.
I'm thinking of flushing and refil the coolant with new blue coolant. DO I need to use distilled water for flushing or use the prestone super radiator flush fluid so that old green is completely out of system.
Thanks
Thanks
