Hello all. I own a 2003 Honda Accord EX Coupe V6. I was wondering if anyone out there had any insight into my problem. I should note that I myself caused the initial problem when I removed the rear passenger brake line to perform some service. Dumb, I know. Anyhow a lot of brake fluid bled out, but I figured I'd solve that problem afterwards by bleeding the brakes, while at the same time adding all new brake fluid. Anyhow, I finished what I needed to do, buttoned things up, refilled the brake fluid reservoir, and reparked the car. At this point I noticed there was no resistance in the brake pedal, and to get it to brake I needed to bottom out the brake pedal. Fine I told myself, no problem. Bleeding the brakes will solve this.
A few days later I used my hand held vacuum unit to bleed the brakes thoroughly, starting with the right rear passenger wheel, to driver side rear wheel, to passenger side front wheel, to driver side front wheel. Once I was done I got in the car, turned her on, depressed the brake, which was still offering no resistance, removed the parking brake, put her in reverse, and she shot off with zero brakes. I was only able to stop the car by turning off the key, and then pulling the parking brake.
After this someone helped me push it back into my parking space, where I tried pumping the brake a few times, which caused it to go from the prior feather light, no resistance to being rock hard, and impossible to compress. I also had the additional problem of the car not starting. Plenty of juice, but it simply won't start now.
I know I screwed up, so no need to let me know that, though if you feel the need to do so feel free. I really would just like to know what I need to do to fix the issue. Is the problem with there being air in the pressure accumulator unit? I read that this unit could cause issues if you lose brake fluid?
I'm pretty sure my bleeding got the air that was in the lines. Is the problem excess pressure in the lines, as maybe I did not thoroughly remove all the pressure before I bled the system? Any insight would be greatly appreciated.
