21 - 24 of 24 Posts
I'm having the same issues as you are describing. Battery, alternator and starter all say they are good. Did you ever figure out what the issue was?
Do you have a old OEM starter or an aftermarket starter?
As far as I know it's the OEM but I can try and find out. I've only had the car for a year. Bought it from a friend. A couple of weeks ago It was not starting roughly 3 times, before it would finally crank. So, I changed the ignition switch. Now it will start the first time, it just seems like it's taking longer than it used to.
If you have a scanner that can read the CKP signal, you can confirm whether the issue is caused by a bad starter. I spent $170 on a scanner just to verify that my new aftermarket starter was the root of the problem. Switched to an OEM one — problem solved!
21 - 24 of 24 Posts
