Cylinder 3 misfired 1 month ago, all spark plugs were changed and car has been running fine. However, in the past two days my engine has misfired twice on the same cylinder 3. Is it more likely due to ignition coils or vcm?
Cylinder 3 is the cylinder that gets deactivated the most, as it is deactivated in both the 4 and 3 cylinder modes.As far as VCM I believe I am correct that cyl 3 typically is the one that is always operation when it does the 6-4-3 deactivation so it may just be weak. That's a guess though until we know for sure if it truly operates in that manner.
Do you burn oil? Cylinder 3 with VCM tends to foul that plug. Had that issue on a delivery a couple years ago in friends wife pilot.Cylinder 3 misfired 1 month ago, all spark plugs were changed and car has been running fine. However, in the past two days my engine has misfired twice on the same cylinder 3. Is it more likely due to ignition coils or vcm?
Less use confounds the problem and probably leaves that cyl 3 injector suspect.Cylinder 3 is the cylinder that gets deactivated the most, as it is deactivated in both the 4 and 3 cylinder modes.
The cylinder that gets deactivated the most is the one that is going to have the most issues. I seriously doubt this is an injector problem. It sounds like a very typical case of plug fouling from VCM activation.Less use confounds the problem and probably leaves that cyl 3 injector suspect.
