Will a 2016 i4 Sport dual exhaust fit a 2016 i4 EX-L? What extra/different parts do I need or are they all plug and play?
I just want a decent close-to-oem dual exhaust for my EX-L instead of a single exhaust.
Thanks.
Alright man, here is the deal,
take your time,
do your home work before you make the switch. I did same thing with my 15 Ex-L where i converted single exhaust to dual exhaust using OEM dual muffler (pick it up from local honda dealer) from 15 Sport/V6. For my 15 model the SPort/V6 has same parts.
Now,
do your home work first, find out the B-Pipe measurement between your EX-L and Sport/V6 - In my case, my Ex-L B-pipe external diameter is 2.35 Inch where Sport/V6 are 2.25" (small). So when I made switch (you can see
here my thread ) I didn't take in consideration of the pipe size so my air flow was going from 2.35" pipe to 2.25" pipe (it was chocking) where two pipe split to muffler. I was getting lot of back pressure and my gas pedal got heavy, means i have to push little hard now this may be different story for other.
Long story short, take a look above thread last post where i have before and after shot where i asked my muffler guy to put bigger pipe between my OEM (2.35") to two split er (each pipe on my dual muffler are 1.79" so basically going into 1.79x2 = 3.58").
Here is two pictures that i found from online about your single muffler 16 EX-L and 16 Sport. Even in picture the B-Pipe (#5 in single exhaust ) and #4 in dual exhaust size looks different. The Single exhaust has bigger pipe to me but double check.
I hope this info help.
