Thanks
@Sammbpbsb - that's more in line with what I would have expected, given the fact that the Hybrid doesn't use the actual brakes all that much vs. a gas-only Accord - and especially in my case where most of my mileage is a constant speed without a lot of starts and stops.
Couple questions for you:
Is your Gen 10 Hybrid an early year in the 2018-2022 model run (maybe a 18' or a 19')? I'm wondering if Honda changed the software in the Maintenance Minder on later Gen 10's? Mine is a 22, last year of the model run.
A little off-topic here, but I love the fact that you're at 170k miles now! Any other significant maintenance items you've had to deal with?
Thanks!
To your first question, I have 2019 Hybrid which I got new at the start of Covid in 2020.
To your second question, everything was wonderful up until I reached 162,000... I got a blown headgasket. Symptoms were that one day while I was in stop and go freeway traffic in Socal, when the engine turned on, it started misfiring and engine light started blinking. Pulled off freeway and turned off car then back on and started working like normal. A week later, driving home late at night on freeway in 50° weather, I got a message saying engine temperature near limit, slow down and avoid high acceleration. Made it home, fluids were good, oil, coolant and reservoir for inverter and coolant. Next day checked fluid again and tested it out, did some pulls and got message again. This time, I checked underneath oil fill cap... Milkshake...
I tried going through Honda for a goodwill repair, but they denied it. So had to pay out of pocket, $4,800 for a new headgasket and machining and new plugs.
Car works like normal and MPG is actually a little better, averaging 51MPG, this is freeway driving mostly. This issue really bummed me because I babied it, no hard acceleration, never driving over 85 mph, but I still got this major failure.
