any of you noticed a harsher ride? I haven't but a buddy put one on (20mm I believe) and it seems to ride like a rock....suggestions?
Thats because on each models the shocks and springs are specific to that model . that is not even talking swaybars differences .there is a huge difference in ride between LX and EX L4 accords although the specs seem to be the same!
According to some online reviews, the main difference is because of tires.there is a huge difference in ride between LX and EX L4 accords although the specs seem to be the same!
LX have 16s and EX have 17s which means less sidewall on the 17s for a less cushy ride or whatever adjective you want to throw in there. And I just checked parts catalog and LX 4 door vs EX 4 door both 4 cylinders have same front strut and spring part numbers. Didn't check rears but I would assume they're the same as well.According to some online reviews, the main difference is because of tires.
i thin the only other change besides the wheels/tires is the ex comes with the front strut bar also. not sure if that affects ride at all.LX have 16s and EX have 17s which means less sidewall on the 17s for a less cushy ride or whatever adjective you want to throw in there. And I just checked parts catalog and LX 4 door vs EX 4 door both 4 cylinders have same front strut and spring part numbers. Didn't check rears but I would assume they're the same as well.
i thought the LX models do not have front strut bars? it's missing some studs which are filled with stickers or something, and the only way to put the oem strut bar is by changing the strut mounts to the EX models that have itLX have 16s and EX have 17s which means less sidewall on the 17s for a less cushy ride or whatever adjective you want to throw in there. And I just checked parts catalog and LX 4 door vs EX 4 door both 4 cylinders have same front strut and spring part numbers. Didn't check rears but I would assume they're the same as well.
no, the LX does not have a strut brace that goes across to each strut hat mount ,they all have 26.5mm front bars (sedans). The difference as I mention before is shock valving , spring rates and of course the LX has 215/60/16/ series vs 225/50/17 series tires, this firms up ride and input response .i thought the LX models do not have front strut bars? it's missing some studs which are filled with stickers or something, and the only way to put the oem strut bar is by changing the strut mounts to the EX models that have it
How is that so when the part numbers between LX and EX models is the same?The difference as I mention before is shock valving , spring rates
there not the same, different shock ,springs for each model. Some models share same shock , like LS coupe and V6 sedan, but on sedans the part numbers are different across all models (there like 6 different springs ) . It depends on transmission type , engine type and model type .How is that so when the part numbers between LX and EX models is the same?
Shocks and springs are different though they are priced same. There are lot of subtle differences between EX and LX. I wondered why dealerships never try to up sell the higher trims.there not the same, different shock ,springs for each model. Some models share same shock , like LS coupe and V6 sedan, but on sedans the part numbers are different across all models (there like 6 different springs ) . It depends on transmission type , engine type and model type .
here one example LX front shocks/springs
http://www.hondapartsdeals.com/hpa_...rID=4&GradeID=5&AreaID=2&TransmissionID=7&SectionID=6&IllustrationGroupID=16231
EX front shocks/springs
http://www.hondapartsdeals.com/hpa_...rID=4&GradeID=8&AreaID=2&TransmissionID=7&SectionID=6&IllustrationGroupID=16231
