Does anyone know the correct battery size for the 4 cyl models? None of the online lookups have the '13 Accords yet. When I search for the 2012 model it says Size 35. I want to confirm.
Thanks!
Thanks!
Duuuuuuuuvallllllll! :banana:Finally another person from Jacksonville. Sorry I can't answer your question
Why would I do this? 24's aren't inherently more powerful than 35's are they?Rip out all the plastic and put in a group 24...trust me....
If it fits it couldn't hurt!i got a spare optima red top . i think it 800 cca . should i put it in ��
Why replace it if the current one is working? Every little OE Honda battery I have had has lasted longer than the larger replacement. CCA without durability is meaningless.
Its the "bigger is better" mentality.Why throw a perfectly good battery away? In five years or so when the OEM battery dies I will put a much bigger battery in the available space. Until then that little OEM Honda battery gets to keep working.
Sure. I don't see why not. Pull up a parts diagram from a V6 and see what you needCan the V6 hardware be bought to "neatly" fit a 24F in an I4? Not of fan of bending stuff to force fit.
