1 - 7 of 7 Posts
kfohoro
Discussion starter · #1 · (Edited)
Hi! I replaced the passenger side mirror recently and now trying to recalibrate the camera. I have read up on the appropriate steps, watched several videos, and have my six-dot target all ready to go. From all of the info I see to get to the right menu screen to start the aiming process, you need to press three buttons at once-- (audio) power, menu, and day/night button. Ok, I have tried doing this many times with no luck. Nothing changes. Does anyone have any other ideas? Thanks in advance for your help!
That is the right combination, you need to try it more than once preferably with two hands. Press and hold for few sec. Have to press just right that menu sensor button can be tough though as it has no feedback like the other two physical buttons.
Discussion starter · #7 ·
any tricks to the trade you can share?
Yes! Don't push "menu" as you would on the other two buttons-- that are actual buttons. A touch did the trick. At first, the compass mode came up and then I tried it one more time and it worked. Tricky with two different hands as all three are too far apart to use one.
1 - 7 of 7 Posts
