Can you request Honda to bump the idle speed up a bit to stop vibration? I don't mind a 1-2 mpg decrease as long as it's not a huge decrease of mpg and it stops the vibration. Even if it meant signing a waiver form about mpg loss.
I respectfully think you're asking the wrong question. It should be, what's causing a vibration at idle? Include whether i4 or V6 and some detail.
4cyl/CVT seat vibration at idle. The Seats do. 4Cyl CVT.Your car vibrates at idle?
It's the engine's RPM, not the CVT. When the car decides to idle at just a tad higher RPM, the car feels like a V8 Lexus. When the RPM drops, it vibrates like a 3 cylinder. A simple change to instruct the engine to never drop below a certain RPM, and the problem goes away.That's a normal part of the CVT.
While I agree with what you wrote I consider this vibration to a blight on Honda. I frequently rent mid size 4 cylinder cars (Camry, Legacy, Fusion) and none of them exhibit the vibration that the Accord 4 cyl does. It makes Accord feel very unrefined.the 'problem' is a Honda. they decided to go with a high displacement 4 cylinder engine. with their programming wizardry and engineering mastery they have achieved massive power (on 87octane) and exceptional fuel economy. an engine like this would vibrate to no end so they have a nifty oil pump/dual balancer shaft assembly driven via a baby timing chain bolted to the bottom of the block in the oil pan. without substantial motor mount changes this is it - try to enjoy the car for what it is - an awesome machine! feel the vibration and imagine all it's moving and turning parts in harmony doing what has to be done - get you to point B.
civics don't have as noticeable a vibration due to 1.8L. there isn't a balancer system at in the 1.8L AND that car only has two motor mounts lol! when you start going over 2.0L you feel it more an more and require a balancer system to reduce (not eliminate) vibration.
it will be very interesting to feel the new 2.0L civic and especially the 1.5L turbo civic.
Why are you crying because your car is vibrating? Vibrating is a normal Honda car characteristic. I rather take a vibrating car that is reliable than any other car brand that is spontaneously prone to break.Can you request Honda to bump the idle speed up a bit to stop vibration? I don't mind a 1-2 mpg decrease as long as it's not a huge decrease of mpg and it stops the vibration. Even if it meant signing a waiver form about mpg loss.
My 2008 I4 Camry vibrates even more than my Accord when stopped in gear. Shifting into N makes it go away.While I agree with what you wrote I consider this vibration to a blight on Honda. I frequently rent mid size 4 cylinder cars (Camry, Legacy, Fusion) and none of them exhibit the vibration that the Accord 4 cyl does. It makes Accord feel very unrefined.
Wow, even a Legacy? Yikes. I always thought Subies were the absolute worst for vibrations. Their flat-4’s rocking couple is far more harsh than the secondary balance problems inherent to an I4 engine, particularly larger displacement I4s. Ironically the flat-4 engine has no primary or secondary balance problems but that rocking couple is nasty.While I agree with what you wrote I consider this vibration to a blight on Honda. I frequently rent mid size 4 cylinder cars (Camry, Legacy, Fusion) and none of them exhibit the vibration that the Accord 4 cyl does. It makes Accord feel very unrefined.
