1 - 20 of 44 Posts
edwilson13185
Pittsburgh, Pennsylvania
***This information only applies to the '03-'07 K24 5AT models***
I thought I'd share this info for the maintenance-minded. Some (or all) of this information is duplicated elsewhere on the site, but I couldn't find a step-by-step process for doing this, so I thought I'd post mine. The ATF filter on the K24 ATs sits on top of the transmission's bell housing, just to the left (passenger side) and aft (toward the firewall) of the air box.
I'd change the filter after the car has been sitting for a few hours. There will be less fluid in it that way, which makes the job less messy. This job also involves a bit of leaning over the fender, so you might want to drape the fender with something so you don't accidentally scratch it. I was able to complete the job with almost no mess and no marred fenders by following this advice.
The basics of how I changed it:
* ('03-'05 only) Remove the 10mm bolt from throttle cable bracket; move cables as necessary
* Remove the 10mm bolt from the right (driver's) side of the filter retention bracket
* Remove the filter retention bracket
* Lift up the filter and place a shop rag under it to absorb ATF
* Compress the hose clamp tabs and move the clamp aside (do this on the input/output sides--you only need to move it a few inches).
* Grasp the filter and one of the hoses with your hands; wiggle the hose and pull outward a bit to remove the hose. Do this for both sides. Don't use tools to hold the hose while pulling, you might damage it.
* Connect the new filter to the input/output hoses, move the clamps back into place, replace the bracket and its bolt, and replace the throttle cable bracket and its bolt.
* Installation is the reverse of removal. The filter is directional; be sure to reinstall it in the same orientation you see in the photos in my next post. Also be sure to pay attention to the tab on the left (passenger's) side of the filter retention bracket when reinstalling it. Make sure it's seated properly before bolting it in.
The '06-'07 K24s have DBW, so there are no throttle cables to get in the way.
Overall, it was a pretty easy procedure. It took about half an hour, and most of that was spent trying to move the clamps. I ended up using a pair of lockable needle-nose pliers for the back (firewall side) one and a wide-jaw pair of channel locks for the front (radiator side) one. It's easier to get at the front one from the top, while I moved the back one from the back side. The dealer wanted $75 to do it, so it's definitely worth your time to do it yourself.
I used part number 25430-PLR-003. After being told by one dealership that it was a bad part number and being quoted $39 for it from a second, I ordered it from Majestic Honda (www.hondaautomotiveparts.com), where it's known as item number 374500. If you can't find it that way, find the "AT ATF PIPE" group under Majestic Honda's parts lookup and it's part 004. Their price was $14.04 plus shipping and $4.95 handling. Order a couple of them if you can to spread the shipping/handling costs over more parts. Please post here if you know of someone with a better price. I know some of this information is in the FAQ, but I added it here in case you missed it there.
I hope some of this information helps. If you have any questions, please ask. I'll check this thread for a couple of days.
Anyway, a few pictures:
One is the part in the bag, with the part number label. Show this to the Honda parts guys when they tell you it doesn't exist or that it's not available in the U.S. Another is the filter canister cut open with the top removed, another is a shot of the bypass valve, and another is a section of the filter media that I cut apart out of curiosity. This isn't even listed by Honda as a maintenance item, but it can't hurt to change it every 20,000-30,000 miles or so, especially because it's such an inexpensive and easy job.
Discussion starter · #2 ·
Here are two more pictures; one shows you the location of the filter, and the other shows everything you need to remove (except for the throttle cable bracket; just follow the cables toward the firewall and you'll see it).
How many miles on the Odo when you did the ATF and filter change? I've got mine read to go possibly tomorrow, if I'm not too busy. I've got 28K on my Odo.
I ordered my filter (and fluid) from Bernardi for about the same price.
Thanks for the tip, Jeff. Unfortunately, I bought a second one of the Honda filters. I'm in the midst of doing the 3x drain-and-fill, though, so maybe I'll just bite the bullet and stick a Magnefine on there while I'm at it.
Namegoeshere: I have 135,000 miles on the clock, and this is the first filter change. I'd have changed it much sooner, but I didn't know about it until recently. I've changed the ATF every 20,000 miles since I bought the car new, and I'll change the filter each time I change the fluid from now on, as well.
Have you changed the pcv valve out yet? Hopefully its not the original and best to go with an oem version. I remember Fredsvt saying the 7th gens should be replaced every 60k. Thats usually when the spring breaks in the pcv valve.
Surprisedly, that filter looks pretty good for that many miles on it. I got 50K on my 06.
I'll probably get around to it when it warms up this spring. I still have that uneasy feeling about Honda transmissions after going through the problems with my former 02 Accord.
But THANKS for that information. I've kind of glanced down there a few times but never really figured out where the filter was. Surprise to see it's an inline hose filter and not attached permanently inside the transmission itself like that of Fords and GM's. Doesn't look hard at all.
Thanks a million. You answered a ton of questions in my head I had about doing this. Make this a STICKY!!!
Do have a question, does the filter and the housing come in one piece? Or do you have to seperate the housing and install the filter alone?
This may be a stupid question, but do 6MT's have a filter anywhere?
Just checked on something. There seems to be different transmission filters. My 06 V6 doesn't have the through hose filter, but rather the filter is located in the transmission itself. I guess there are different AT models.
The I4 and V6 filters are entirely different. The I4 is an inline filter, the V6 is a cartridge that's kinda in the engine/trans. I don't recall coming across a DIY or much info on the V6 AT filter here, but it should be very similar to the one in the 3rd gen TL.
Thanks. I didn't think it would be that different. Looks like there could be one hell of a mess when you pop open the filter cover. I mean, that looks like it could hold a 1/4 of a quart and no way to do anything about it but pop the cover off slowly and try the mop and sop method with paper towels.
Discussion starter · #19 ·
Audi Junkie: I don't mind at all. I'm glad you found it useful/interesting.
SatinSilver: The PCV valve has been replaced before.
Schmoe: Yeah, as others here have already said, the K24 AT is the only model that has this inline filter. The V6s are, unfortunately, more complicated. I'll edit the original post to make that more clear for others who read it, sorry for the confusion.
Yes, sort of. It's a screen in the bottom of the trans that's replaceable by removing it from the outside.
BUT.... You must drain the unit and be extremely careful about anything getting in the pump's inlet. Yes, the 6mt has positive pressure lube, unlike most manuals which are splash lube only. If anything gets in there, it could lock up the pump and the trans wouldn't be far behind.
Here's a link to an exploded view with the screen and oring.
http://www.hondapartscheap.com/sout...MISSION+CASE+(V6)&vinsrch=yes&ListAll=&prdrefno=&act=&count=0&quantity=0&qty0=1
1 - 20 of 44 Posts
