The serpentine belt on my V6 has always occasionally squeaked when it got wet, but it always went away quickly. However, last year, I decided to replace it as a preventative measure, and recently it has started squeaking non-stop. Belt conditioner just makes the problem worse, while chemical guys plastic conditioner will usually shut it up for a bit.
Typically this would be a bad tensioner, but mine seems fine, it doesn't vibrate at all with the engine running, and I have to put my back into it to get it to budge at all. Similarly, the idler pulleys spin smoothly when they're unloaded. I suppose it could be the alternator or A/C pulley, but the sound doesn't change when you turn on the A/C or radiator fans.
This leaves the 6 month old belt as the only thing that's changed. It was just the cheapest thing they had at Autozone, no idea what brand, the logo has faded already. Should I buy a nice OEM belt or something and try that?
