TIA for your wisdom.
Purchased 2005 2.4 MT for project car with bad engine (jumped timing). It came with one key. It did run when I got it, with frequent misfires.
Just finished the engine swap and went to start it up. Crank…no start. It DID randomly start and run once for about 2 seconds before stalling, when I had one spark plug out. Diagnosing this showed good fuel, compression, but no spark on any cylinders. No power to ignition coils. I was checking fuses and relays when I read about green key symbol/immobilizer system. I DID have a flashing green key on the dash with key in ON.
So I go to programming mode (key ON, press lock, key off, x4) and cranked it…and it started! Great, problem solved with zero new parts. Let it run for a few minutes, turned off, cleaned garage. Couple hours later I’m ready to run it longer, so I crank…and crank and crank…no start. Once again, no power to ignition coils. This time there is NOT a green key flashing on the dash. For that matter, the green key on start-up showing that the immobilizer system is live is also not showing up.
I tried programming the key a couple more times, no good. Thinking the root problem might be in the key, I notice that the red LED turns on when any button is pressed, but nothing else happens—lock, unlock, panic, trunk; no response. The master lock button in the car does work though.
I checked the fuse for the immobilizer system, it’s good.
may be relevant—car has been sitting 8 months during engine swap. I have no rodents in my garage, so it’s not a new rodent issue.
possibilities I’m contemplating: immobilizer circuit in the car has some intermittent failure. If that’s the case, I would prefer to bypass it entirely at least as a stop-gap.
or, the chip in the key is damaged/dying. Maybe it was good before but didn’t like sitting around for 8 months. I think this is separate from key fob battery, so would maybe mean getting a new key. And paying a mobile car locksmith to set it up.
thoughts? Theories? Other things I should try before getting new key programmed, or bypassing immobilizer system?
