1 - 15 of 15 Posts
Cleaning and lubing guide pins and inspecting caliper operation is part of a proper maintenance.
It is not BS but usually not very high on priority.
Are you changing pads and rotors ? If yes, have them clean the calipers. If not, don't.
Unless a caliper is draging, then you have to address that issue.
As a Honda service advisor, i would recommend to do the b1 service which includes BRAKE SERVICE..meaning they just take it apart, lube up parts, scrape off any rust, basically making sure they're properly working to mitigate future issues from no upkeeping
As a regualr car guy, i recommend to do it yourself if you're tech savvy, it's very simple.
but to answer your question, no it's not BS because i've seen idiot customers who completely ignore their brakes and they seize up...then they go and blame honda for shit parts...but when really it's because customers are too price sensitive, and didnt want to spend the coin to do it right the first time
Definitely not BS. I don't know what year you have, but early 8G Accords had issues with premature break wear. This is largely due to the rear calipers sticking/dragging. Cleaning the slider pins is essential to making them last. I believe new pads have a spring to help with this. I'm still rocking regular pads. I clean them myself every other oil change.
I will check the pins when I change the brake fluid and take off the snow tires next weekend. Do the pins require any special grease? I am a master certified truck mechanic but have no experince with Honda.
I agree I had to replace all my calipers because I didn't do a brake service in the cars 80k lifetime.
Like I said before I don't trust the dealer. I am not sure they would do anything more than spray the brakes down with a can of brake cleaner. I will just do it myself. Does anybody know if there is a special grease required?
1 - 15 of 15 Posts
