1 - 7 of 7 Posts
Were is the EGR valve located
Year make model?
most new honda engines utilize the variable valve timing to cool the cylinders. EGR valves are falling far into the distant past. Thank god....
8th gen V6 engines have them mounted just right of the front engine head. A harness kinda covers the top so ye may have to shift things a bit to remove it.
Note: you cannot block the EGR without throwing an ECL. Though if you pipe air from the air box and block exhaust using a custom spacer under the EGR, it will make the EGR function as if blocked without throwing an ECL. It will lean out the mixture a wee bit, but that is needed for better performance with 89+ Octane
not selling 'egr cleaning' services eh?
while I agree it's another hour less to 'sell', as well as power steering cleaning lol
LOL. I must admit upon retrieving P0401 I can't help but grin knowing I'm about to make a killing. but the technology is so old its about time we loose the extra parts and potential problems.
Power steering flushes are the most neglected service!!! I'm sure you have seen steering effort concerns fixed just by fluid maintenance just as i have. although its nice to see one less engine load, and one less part to remove during a major repair.
1 - 7 of 7 Posts
