Changing my oil tomorrow. Completely forgot what size wrench I need for the oil drain plug. 2009 accord couple lx-s i4. Tks in advance.
No.Got it. Thanks. Just changed the oil. Does it really require 5qts?
Hi everyone. I want to change the oil on my '08 Accord 2.4L, but I don't know what wrench size to use on the oil plug. None that I have fit. What's the correct wrench size? I'm in the U.S. Thanks.
I thought you didn't have a 17 mm wrench.Thanks. That worked. Now, were is the oil fliter located?
I did. I just had to look at the sizes correctly. 5 qts of oil on this engine, is alot.I thought you didn't have a 17 mm wrench.
