YES! Chris can answer this!!
For those that have replaced the front anti-sway bar or the front anti-sway bushings (NOT end links), did you:
- drop the rear side of the front sub frame to get working space? or
- did you loosen just the front bolt of the bracket and bend it out of the way then squeezed the new bushing in?
My front ones are finally squeaking. I crawled under the car tonight and could not even fit a wrench onto the rear bracket's bolt. And if I do fit a wrench on there and manage to start loosening it, the wrench will get stuck. The rear bolt is nearly kissing the chassis with just 5mm of space.
Please exercise your front anti-sway bar wisdom.
thanks!
thanks!
