Status
Not open for further replies.
1 - 15 of 15 Posts
flyfshrmn98
Ive got a set of used Hertz HSK 165 6.5" component speakers and crossivers available. I bought them used from a member on DIYMA and had them in my 9th gen for a while but wasn't pushing them like they need to be so decided to take them out and let someone else get the most of them. One of the speakers rubber surround had a small hole poked in it by the previous owner that was repaired. Both speakers work fine. There are no tweeters included with this. Yes these will fit in the front door of the 9th gen no problem with a schoshe speaker adapter. Asking $200 +shipping
What- Hertz HSK 165 Component speakers and crossovers
Location- St Louis
Condition- Used
Price- $200 +shipping
how do i find out if it will fit an 09 accord coupe. i would buy if it does. you don't need an amp or anything else right
I would recommend an amp to drive them to their full potential, but yes they will work without one. You probably will have to do some google or forum searching about the '09 door depth. Looking at pictures, the opening appears to be identical to the newer ones. I can't imagine much has changed with the door over time. You will likely need to purchase the schosche speaker adapter for any aftermarket speakers. Here is the spec sheet for the speakers
http://www.hertzaudiovideo.com/wp-content/uploads/2014/05/Hertz_HiEnergy_HSK165.pdf
1 - 15 of 15 Posts
Status
You have insufficient privileges to reply here.
