So I don't know too much about brakes, but does this seem right? :
Both of the rear brake pads when I look through the alloy wheel have absolutely zero clearance on the disc/rotor. I walked around my apartment complex looking at other new accords and hondas, Seemed most of them had the same thing if they were Accords, the CRV's and Oddessy's had clearance.
The rear rotors have lots of brown rust looking material, and the front rotors do not.
Has anyone heard of this?
Can fellow 9th gen Accord owners go out to their car and see if the rear brake pad it touching the rotor on both or either side? I don't understand how this could be right.
I do sometimes at only certain speeds get that high pitched sound some find hard to hear but I thought that was the CVT. I took it in to shop a year ago about the high pitch, they said something about the breaks and clearance but that they were 'in spec' and normal.
Both of my rear pads are touching, so were other 9th gen accords when I looked through the alloy wheel to see if there was any clearance.
I am suspecting something is off because of the brownish material (dont think it is rust) forming all over the brake assembly. It isn't really bad, but putting two and two together makes me think Honda is again keeping their mouth shut - just like they did on the 8th gen accord rear break pad premature wear class action lawsuit.
Anyone heard of premature wear on rear brake pads of the 9th gen Accords, possibly due to this clearance issue?
I would love to hear feedback from all the 9th gen owners on their clearance, and if they have none or they can tell there is at least a very small space.
It could be normal, but I am skeptical and wanted to check with people more knowledgable about the brake system on the Accord.
Thanks!
Thanks!
