I want to remove the rear center brake light housing to clean the window and housing. How do you remove this?
You will have to remove the whole rear deck lid, to do so:I want to remove the rear center brake light housing to clean the window and housing. How do you remove this?
Do you have a video of itYou will have to remove the whole rear deck lid, to do so:
- Unclip the bottom of the rear seats and lift the sides
- unscrew the side bolster screws
- remove the side bolsters
- remove the door rubber seal
- remove the side trim surrounding the tiny side window
- and then you should be able to start popping off clips in the rear deck
