Hi All
First of all, thanks to DevinKato on here! Between his pics with descriptions and crutchfields bare bones text only instructions i braved the install of my USA Spec ipod adapter in my new accord last night.
Unit works well, it still allows XM, the ipod control, and the use of my in dash cd changer by hitting the CD button again. Pretty exicted that I have this done already, now next is XM To Sirus conversion!
Thanks to those who post on these threads, i decided to take pics of my install since i couldn't find a detailed description of this on the web. Hope this helps those debating doing anything like this, really easy!!! ** Sorry but don't know how to embed links so had to coordinate pics with numbers for steps.
2008 Honda Accord Radio Removal – Non Nav Unit
Tools needed” 8mm socket, Philips head screw driver, small and med sized. Some heavy duty towels to keep form scratching panels and some sort of tape(painters tape works well)
1. Open console storage door. Pull up console trim panel to release clips, disconnect harness and remove panel. You will pull up first at the area circled below.
2. Pull up the parking break and set the trans to neutral. The entire top to the center console is held in by clips. **(note, once removed be sure to check that the clip brackets stayed on the pegs on the panel, if not in the pic below find the clips, remove them and place them on the posts on the console top so your ready to put it back into place when complete)
3. Remove two Philips screws exposed by removal of console trim panel.
4. Place gear shift in lowest position.
5. Open dash storage pocket and remove two Philips screws located inside. Remove storage pocket assembly. ( really up and in, have to get down low to see these two….
6. Next you need to pull out the storage boxes… *** before you do this tape up the shift lever and all surrounding trim panels, they scratch easily when removing these boxes. Its very hard to pull these out without separating the two boxes, look at the sides and you will see 4 screws(2 on each side), remove these 4 and then you can separate them and ‘easily’ get them out.
*** NOTE ** the first part of removing the center console area is thanks to DevinKato on DriveAccord.net http://www.driveaccord.net/forums/showthread.php?t=16709&page=6
