I would like to share my long and tedious journey to replacing the seats in my 2021 Accord Sport with 2021 Civic SI seats. My local Honda dealership told me it was impossible and the only solution was to purchase a new car. The original seats with the 10 way lumbar torture were causing me massive lower back pain, which has been resolved since replacing the seats.
I first stumbled across this video on YouTube, which is a very helpful guide to watch to get started with replacing the seats. I'm a former Air Force F-22 Raptor mechanic, and I enjoy solving complex mechanical and computer issues. Also, I don't recommend trying to change the seat belts, just swap the seat belt buckles into the new seats. The creator According to Joel does a great job and I would like to add onto his video to solve the wiring issues, which cause the Airbag light to come on and will prevent any of the Airbags from working.
Type R Seats to Accord YouTube Guide
First, here are the results of my swap. You can see the grey Civic SI seats look very nice and there are no Airbag lights illuminated.
Let me know if you have any other questions. Thank you again to According to Joel for making the YouTube video guide.
- Find the right seats: I found my seats on ebay.com . You can also look on copart.com to find a Civic SI or Type R in a local junkyard near you. Just make sure the Airbags haven't deployed in the seats. I highly recommend you look at the seats in person. The first pair of seats I looked at were so rusted that none of the manual seat adjustments were working. Make sure the Airbags and wiring are still present in the seats.
- Remove the Driver's Seat: First I highly recommend you remove one seat at a time. This will help you to isolate any issues related to the Airbag light, so that if the Airbag light comes on, you will know which seat is causing it. When you remove the seats, as is show in the video, I highly recommend placing towels on your door trim and near the center pillar to prevent scratching it. I had to replace the plastic trim on my center pillar because I scratched it so badly.
- There will be three wires you need to connect to the car:
- Blue connector: Leads to the seat belt. You will have to remove the seat belt buckle from the oem seat and swap it into the new seat. Remove the 10mm bolt and a felt plastic clips. Install it into the new seat.
- Yellow Connector: Leads to airbags. Probably best to disconnect your battery when touching these. You will plug this into the car when you install the new seat.
- White Connector: Leads to the Seat Position Sensor, heat, and other mechanical components of the oem seat. The most important thing is to make sure the Seat Position sensor is connected to the car, otherwise the Airbag Light will turn on. The white connector will be different between the SI seat and your OEM seat, so you have two options.
- Remove the white connector (Seat wiring harness) from the oem seat and install it in the new seat.
- Order a new seat wiring harness from the dealership, around $350.
- I opted to order a new wiring harness because I would have to disassemble my oem seat to remove the harness and I wanted to try to resell it
- You can find the part number on Hondapartsnow.com
- Go to Interior/bumper -> Front Seat Components (Driver Side) (Power Seat) (TS Tech)
- It is part number 16, called "Cord, L. FR. Power Seat "
- Remove the seat position sensor from your oem seat and install it in the new seat. It's secured by a single 10mm bolt.
- When you get this wiring harness, the most important thing is to plug the white connector into the car and the black/white connector into your seat position sensor, which looks like this:
- On the Youtube video, you can see it at 13:09. It's on the inside of the left rail of the driver's seat.
- Also, you can plug in the green connector from the wiring harness, which will allow your heat to work in the Civic SI seat
- Install the Civic SI seat into your Accord and then turn the car on to ensure the Airbag lights don't come on.
- If they do, recheck your connectors to ensure you plugged everything in and that nothing is loose.
- Remove the Passenger's Seat:
- For this seat you will have to remove and swap the seat belt buckle, using the steps above.
- Make sure you reconnect the blue, yellow, and white wires.
- Remove the white connector with the wiring harness from the old seat.
- This should be attached to a blue and red connectors, which lead to the Seat Weight Sensors.
- Green connector, which leads to the heat.
- Remove the Seat Weight Sensorsfrom your oem seats and install them in your new seats. These weight sensors are specifically calibrated and designed to work with your car. The Honda Master Tech I talked to told me that the car will not recognize the Civic SI weight sensors even though they look identical to the Accord weight sensors and they will trigger the airbag light. You will have to unscrew the 10mm top bolt from both weight sensors and then two 9mm bolts from each sensor. They look like this:
- You will then have to remove the old weight sensors from the Civic SI seats and install the oem sensors in their positions.
- Then install the oem wiring harness with the white connector into the new seat. Plug the red and blue connectors into the oem sensors.
- Plug the green connector into the new seat.
- Install the new seat and ensure the yellow, blue, and white connectors are plugged in.
- Turn on the car to ensure the Airbag light doesn't illuminate.
- If the Airbag light comes on, recheck all your connectors to ensure nothing is loose.
