Hi folks, Doing my first T-belt job on my 09 Accord V6 AT. I spun the crank bolt on with it's washer and used a ratchet to set timing a-la South Main auto channel (though he never showed himself removing it again) My issue is that I need to get the crank bolt back off because I didn't install it with the pulley and the metal guide, and I can't retroactively fit them over the bolt. I plan to install and torque the bolt at the end.
Problem is I don't have an impact and if I try to remove the bolt w/ a ratchet, it just spins it backwards and throws off the timing.
What is the move for me? My thought was maybe I could cut the belt (with the timing already set) and then remove the bolt w/ a breaker bar?
