In ONE month I loose 10 quarts of oil and always have to top it off, I do not burn oil, no blue smoke ever, no oil in spark plugs, my rear main seal is good along with the valve cover, I clean under my motor and the only spot I found leaking oil is along side my oil pan, so before I go spending money what do you guys think it is? Oil pan gasket or other problem?
this is above where the oil filter tube runs into the oil filter.
this is the down pour of oil that leaks on my driveway. this is the oil pan on the passenger side.
these are the only places with fresh leaking oil, but don't know where it is leaking from
