2. | Ignition Coil - Remove |
3. | Spark Plug - Remove |
1. | Spark Plug - Install |
2. | Ignition Coil - Install |
3. | Ignition Coil Cover - Install |
4. | Maintenance Minder - Reset (With Maintenance Minder System) |
You can find out this information here at DriveAccord because it was posted before. The answer should also be on the NGK website I linked to. Please search for me and re-post this information.What is the part # for NGK for plugs for a 2014 2.4L Earth Dreams?
Thank you! What does NGK recommend for torque? Also, those part numbers you listed, please search for me and tell me what they are for PZEV vehicles and non "California" emission vehicles. Thank you!V6 NGK ILZKR7B11
I4 NGK DILKAR7G11GS
For both I4 and V6 - NGK website recommends the following torque spec:Thank you! What does NGK recommend for torque? Also, those part numbers you listed, please search for me and tell me what they are for PZEV vehicles and non "California" emission vehicles. Thank you!
Why would anyone ignore Honda’s recommend procedure, and instead follow a parts supplier’s recommendation; especially when it comes to torque values to be used on a critical component like Honda cylinder heads. Do you have any reason to believe Honda’s recommended spark plug torque or installation procedure is incorrect?Thank you, but NGK (spark plugs) specifically states to NOT add anti-seize compound.
https://ngksparkplugs.com/en/resources/5-things-you-should-know-about-spark-plugs
Would you please cite a source?
Did you read NGK's explanation of why?Why would anyone ignore Honda’s recommend procedure, and instead follow a parts supplier’s recommendation; especially when it comes to torque values to be used on a critical component like Honda cylinder heads. Do you have any reason to believe Honda’s recommended spark plug torque or installation procedure is incorrect?
Not only did I read it, I’m positive I better understand what they are saying between the lines and that appears to have eluded your own understanding.Did you read NGK's explanation of why?
I didn't think so.
Your view of "Honda's position" is exactly why NGK states not to use anti seize on their spark plugs regardless of engine.Not only did I read it, I’m positive I better understand what they are saying between the lines and that appears to have eluded your own understanding.
Are you of the opinion that NGK knows more about Honda’s cylinder heads than Honda? Seems like a very difficult position to defend.
But while I’m here, and you’re devising your defense of NGK over Honda, I’ll paraphrase NGKs position for you:
“Poorly trained and lazy people who change spark plugs can’t be trusted to read the required torque specifications, much less use an actual torque wrench. We’ve designed an ablative coating that will protect most of these idiots from their own incompetence (nothing is 100% idiot proof) that we think works pretty well. Now if you remove one of our fancy plugs, and wish you reinstall it, you will need to use anti seize compound because the ablative coating will have destroyed itself during removal. At this point, and if you are the idiot we think you might be, it’s probably best to seek competent help.”
Now in contrast here’s Honda’s position:
“Use a bit of anti seize compound on spark plug threads and torque the plugs to the specified value. What is not explicitly stated, but what is implicitly understood, is that you are able to follow instructions, have a torque wrench, and know how to use it.”
What is left is for you to decide which target audience you belong to, and to act accordingly.
Do you think that Honda doesn’t fully understand the lubricant properties of anti seize and therefore didn’t take that into account with their specifications? Does it make sense to you that the lubricant properties of anti seize was just recently discovered by NGK, and that their specifications now supersede what Honda still writes in their factory service manuals today? Could it be that Honda engineers can’t grasp what you’ve embraced about spark plug torque, and that your knowledge is far superior to theirs?Your view of "Honda's position" is exactly why NGK states not to use anti seize on their spark plugs regardless of engine.
From NGK's website "Anti-seize compound can act as a lubricant altering torque values up to 20 percent, increasing the risk of spark plug thread breakage."
Even if you're following the instructions you will not account for the anti seize acting as a lubricant altering the torque up to 20%.
I have nearly 200k kms on my car with spark plugs that have been changed at 160k km. The spark plugs went in dry.
"Honda's position"? Please cite a source where you are quoting from. Thank youNot only did I read it,
First post of this thread, under “Spark Plug - Install”."Honda's position"? Please cite a source where you are quoting from. Thank you
Apply a small amount of anti-seize compound to the plug threads, and screw the plugs into the cylinder head, finger tight, then tighten the plugs to the specified torque. |
You are quoting from a post you think is from Honda. No such citation stating this is from Honda.First post of this thread, under “Spark Plug - Install”.
There are several possible sources of the images and information provided by the OP in the opening post. In decreasing probability they are Honda or a publisher authorized by Honda to develop and distribute a factory service manual, primarily for the use of Honda dealer or other authorized technicians that from time to time will be required to work on our Accords.You are quoting from a post you think is from Honda. No such citation stating this is from Honda.
