1 - 6 of 6 Posts
VictorW
I always wanted well lights in my accord because I have them on my TL SHAWD from the factory. Does anyone know if theres a kit for this? I saw that there was a accessory kit from Honda, how is that one?
Thanks!
I have the honda kit, it's worth it if you want footwell lights. I even took mine a step further and extended it around the car to the rear footwell, glove box, and center console, even did the close up part up the center console. Car is completely lit at night, which is awesome with a black interior where it's hard to see. All the parts are easily obtained from a dealer ( i used CHH) for small $$.
I posted a thread here, search "extending" and that should pick it up. You might also have to drill out the diffusers for the factory kit to make them brighter, easy, use a sharp brad point bit smaller diameter than the diffuser and it cuts it clean. You'll see what i am referring to if you go with the factory kit.
1 - 6 of 6 Posts
