1 - 10 of 10 Posts
TXP
Austin, TX
At a high level, this is the issue my 44,000 mile, 2016 Honda Accord EX-L V6 is having. Intermittent long cranking time when the engine is warm’ish. The normal cranking time is 1 - 1.5 second duration. When it does exhibit the issue, the cranking time is about 4 - 5 seconds. The issue is getting worse and happens on a weekly basis now.
  • Occurs when the engine temperature gauge reads just right in the middle between normal operating temperature and the cold mark. This seems to be a key point. Granted this may be a narrow temperature range because the temperature gauge is one step above an ‘idiot light’.
  • Normal (full) operating temperature starting is just fine.
  • Cold (ambient temp) start temperature starting is just fine.
  • 10k miles ago it used to have what seems like a slight cylinder misfire once in a long time for a few seconds after turning over when cold. Haven’t noticed this misfire for thousands of miles and no code was ever logged.
  • The battery was replaced by the dealer just under 2 years ago.
  • The starter cranks the engine as fast as it ever has, so no starter performance degradation.
  • TBS performed for fuel system reprogramming probably over 2 years ago. No engine stalling or loss of power had happened, so the dealer didn’t replace the fuel pump, per TSB instruction.
  • I run either Quik Trip, Costco or HEB gasoline. QT and Costco are “Top Tier”, for what that’s worth.
  • Been running VCM Tuner II to disable the VCM for about the last 7K miles. However, for the last 2 months, I’ve had the unit turned off. The way the unit is designed to work, it shouldn’t affect what the engine computer reads except right at the point the engine reaches full, normal operating temperature. Otherwise it sends the real temperature reading to the computer.
  • I can sometimes notice a stronger exhaust smell right after a long cranking event. Then again, the car has always seemed to have a slightly stronger exhaust smell upon startup for about 15 seconds. I don’t go around sniffing the exhaust, but it has never failed to Pass annual emissions testing.
From the internet, I’ve compiled a short list of possibilities and my thoughts on them.
  • EGR system. Unless the engine is running out of spec, the EGR passages in the intake shouldn’t be clogged by this point (44K miles). The EGR likewise shouldn’t be failing this soon.
  • Battery ground (-) terminal. The battery is grounded to the front top crossmember. As finicky as electrical systems are in modern cars, all sorts of strange things can happen if electrons cannot flow just so. The connections seem fine, but I’ll take them off and clean them anyway. People suggest running an additional ground wire onto the engine.
  • Leaking fuel injector. From what I’ve read, this can cause a loss of fuel system pressure after the engine shuts down and potential rich F/A reading (when starting).
    • The loss of fuel pressure could potentially cause a delay in the engine firing over while the fuel system re-pressurize. If this was the case wouldn’t I also see long cranking time when the engine is cold?
    • As for a really rich F/A mixture sitting in the intake manifold or in one cylinder, I’m not 100% sure how that could affect the ability to start. I don’t think the engine could detect the condition and not fire the spark plugs since all the sensors are up wind of the intake manifold. Maybe the F/A mixture is too rich for the ignition of the fuel? Since I don’t think this is a “direct injection” engine, I supposed that the rich F/A mixture could flood the entire intake manifold and result in super rich F/A in all cylinders, thus preventing combustion for 4 seconds while super rich mixture is cycled out of the cylinders.
  • Check valve failure in the fuel pump. Like the leaking fuel injector, this could result in a low pressure scenario that takes a few seconds to build back up before the engine gets the necessary fuel squirting into the engine. Again, wouldn’t this happen also on cold starts, not just warm’ish starts?
I’d rather not take the car into the dealer before I make a respectable attempt to avoid a 4-digit repair bill. Dealers are good at installing new parts, but not always the best at diagnosing. I’d also rather not prematurely wear out my starter since they can be expensive and not something I think I’d enjoy replacing myself on this car.
If women cannot find you handsome they should at least find you handy. Therefore, I’ve become respectively handy under the hood. I’m willing and able to try some repairs, but I need wiser minds to help me find a starting point and prioritize my work.
Thank you for reading this far.
I'm having somewhat of the same issue. Mine is a 2017 EX-L V6. Usually only happens after the car sits for a couple hours. Never when the engine is cold or hot. It will crank then when it gets to the point which it normally starts it briefly stutters then cranks again and starts.
Too all, buy a $15-$20 ($50 @ dealer) relay for fuel pump and keep it in your glove compartment. The contactor on these relays will fail intermittently. Took 4 days for mine to fail completely. If your fuel pump relay fails you can pull one from another component to get your engine running. Just trust me on this one. Cost me $184 for dealer to diagnose and replace it.
Reactions: smallpenguin
Interesting story, do tell more
I have the same exact problem. I took it to the dealer but they have no clue what is wrong. They said unless there's a code, they don't really know what is wrong. Have you found the issue yet?
Here is an update and ultimately I think the answer in my case.
I checked, tinkered with and cleaned several things on the engine. Ran some wicked strong fuel treatment through it. The fuel treatment helped, some, I think. Still, nothing really solved the longer cranking times.
In the end I removed the "VCM Tuner II". Within 1000 miles the starting issue disappeared completely and not one long crank time since. My theory is that over time the VCM tuner threw the engine settings off to the point that the engine had some issue starting normally in that specific window of engine temperatures.
The other thing I observed was that the MM for the oil changes went much longer than previously by about an additional 4K to 5K miles. I figure this is due to the way the VCM tuner works. It reads the engine coolant temp and forwards that to the computer until it reaches a certain temp, then after that it sends a programmed temperature reading to the computer that is just below where the computer would allow the regular cylinder deactivation to be enabled. The fail safe is if the engine temp gets too high, it would then send the actual temp so as to hopefully not cook the engine. Since the MM never saw normal or elevated temps, I guess it figured the oil was not going to need to be changed as soon.
The "VCM Tuner II" didn't work out, but then again by the 2016 models Honda had tweaked enough with the transmission and engine that the issues with the VCM wasn't hurting the transmissions enough to warrant deactivation.
@voond I don't know if you have any VCM disabler, but if you do, that might be the culprit. If you don't have one, there are several things that could be causing the long cranking issue either directly (EGR, fuel pump, etc) or indirectly (things like the VCM Tuner II that threw off the car's adaptable computer mappings). I'm sorry to say that most of the posts having to do with long crank times involved a lot of mechanic hours (and $$$) with only some people ever getting it figured out. Maybe my list of 'possible problems' in the first post can give you a starting point.
I will have to look into the VCM. The only thing I attempted to change was the EGR which made no difference. Also I have a 2012 Honda Pilot EXL-RES. We had this problem for a few years now; I doubt it is the fuel pump because it that was the problem, it would have gotten worst over time. The symptom is the same all these time. If I put the key to "on" position for a few seconds before starting it, the car starts up fine, no extended cranking time. Like you, cold cranking is fine, starts right up. When it is hot, it starts right up too. Only after sitting for about 2 hours (warm temperature) that the problem comes back. Thanks.
I just replaced mine. Thanks!
1 - 10 of 10 Posts
