1 - 20 of 22 Posts
reframmellator
· Moderator
Capital Region, People's Republic of NY
I have a 2004 EX I4 5MT with 142,500 miles. This morning I experienced the second disabling failure in our family's record of eight Hondas and about 800,000 miles. Both occurred around 140,000 miles, so I ain't complaining.
After backing out of the driveway this morning to go to work, I shifted into first, whereupon I heard a loud noise and the car didn't move. I can shift freely into every gear, but there's no transmission of power to the wheels. If I rev it slightly in fourth gear, I can hear [external] rotating parts hitting each other.
There are no puddles under the car, just a little pile of dust and a rubber-encased metal donut-looking thingy. It is labeled SDA-A51. The inner rubber sleeve is torn, as you can see in the picture on the left below.
Any idea what happened here? I once replaced the half shafts on a Taurus wagon and it wasn't that bad. Is this a DIY job, should I have it towed to the dealer, or is it going to be so expensive I should think about retiring it? KBB private party value is about $6k.
Looks like a broken axle to me. I'm assuming they're original?
I'd also look under the hood and have someone move the shifter lever at the same time... Wonder if it could have been a shifter bushing breaking,a nd the loud noise was when you half engaged the trans while letting the clutch out, and it broke mid-process? Doubtful, I know, but that rubber bushing doesn't look big enough to be off of the axle, IMHO.. :dunno:
Let us know what it winds up being!
Well, let's hope.. Because axles aren't that expensive.
Subscribed. :yes: Keep us posted.
Discussion starter · #6 ·
So the half shaft is broken on the passenger side. May be coincidence, maybe not, but the same side on which I hit a curb at about 10 mph to avoid a minivan changing into my lane. Happened almost a year ago.
I could do it myself but I'm choosing not to. I'd need a 36 mm socket and probably a 3/4" breaker bar for openers. I'll leave it to the skilled techs at Saratoga Honda. They tell me I may be able to get an aftermarket remanufactured half shaft if Honda doesn't offer one.
Plus my $0.26/month towing rider with State Farm covers towing to the dealer. Completely.
Now I definitely want to hit the 200k miles mark.
:eek:
Great that it is only an axle, though!
I'd doubt it was from that curb, but who knows.. :dunno:. I'd suggest doing the other side as well, but that's just me.
4th gear probably made more noise because it was swinging around at ~45MPH. :eek:
I guessed it right! Woohoo! What do I win?
Auto Zone or Advance Auto should have 1/2 shafts.
I replaced both on the 2005 a few years ago. I think they were @ $65 each. :dunno:
Be thankful it happened there and not in the middle of nowhere.
So good to hear it was only that. You'll have 'er back and driving around in no time. :thmsup:
Have never saw a half shaft break like that, only usually with a ripped boot and the CV joint losing all it's lube.
Just looked them up for Autozone and you're right, about $70 for each side.
If you want a good laugh look up the same CV axles on Honda Parts Now and look at the price...they're in the $400-$500 range FOR EACH SIDE!! What a rip off...
Glad your fix is as simple as the CV axle though :thmsup:
For 145k miles that is some serious rust. You must live in the north-east and never wash your car during the winter months.
I refuse to buy a car that has spent anytime up north where they salt roads, been there done that...
Discussion starter · #15 ·
For upstate NY and ten winters, that is very little rust, actually. And I do wash my cars frequently. Many ten year old cars up here have much, much further advanced corrosion - if they're on the road. This one has zero body rust. It's part of the price we pay for living in a socialist workers' paradise. There's a price to be paid anywhere you choose to live.
Thanks to all for the advice on aftermarket vs Honda. Just got off the phone with the service rep - they will go aftermarket, which probably means remanufactured, which is fine. Like $400+ fine.
Don't miss that part of living in NY. Do you ever jack it up and hose off the underneath?
Discussion starter · #18 ·
If it's warm enough, I go to the coin-op car wash, load quarters into the machine and spray the daylights out of the underside. If it's too cold for that I do the drive-thru with the undercarriage wash.
In the spring, I just get under using my trusty garden hose. Never really jacked it up to do it.
By the way, it's still the original exhaust.
Your car looks great. And that rust is nothing. It's just a fact of life in NYS.
If I was buying a car and saw that rust there I would be all about it. I have driven much much much worse. My 94 LeSabre, pull up the back seat and you can touch the ground.
Discussion starter · #20 ·
Update - no other damage. Dealer installed a NAPA axle and replaced a cracked $0.26 shaft seal while he was in there. I asked and he suggested a PM on the other axle/seal wasn't really necessary. Plus they repaired my rattling heat shield over the exhaust pipe - all for about 40% of what a new Honda axle would have cost.
I do most of my own maintenance but I like the service department at my dealer because they are willing to work with you.
Back on the road today!
1 - 20 of 22 Posts
