I replaced my rear rotors and pads and now there is no parking brake. I checked to make sure that both cables were still attached to the calipers which they are. Does it need adjustment when new brakes are installed? :dunno:
I screwed them in clockwise.Did you rotate piston in or push it in?
The e-brake moves without any resistance and no stoping force.you might of damaged the screw mechanism in the piston .
You have to screw the pistons in on rear brake calipers that have built in e-brakes .
take the calipers off and see if you have gap between pads and rotors with car lifted, wheel off .
you could try and rotate the pistons, they maybe just stuck .
Does e-brake move or it just doesn't stop car .
That I didn't know or do.Also make sure the cross slots on the piston face are aligned with the pips on the back of the inboard brake pad.
Yes, check that, that brake pad is engaged in the piston grove .That I didn't know or do.
Thanks. I will double check that:thmsup:Yes, check that, that brake pad is engaged in the piston grove .
there should be no real gap between piston , pad and rotor .
Just a few thousand of inch on rotor .
Yes I did and it stiffened up and applies the rear brakes and stops the car from rolling but doesn't lock up the rear tires. They aren't grabbing tight enough.When I did my rear brakes last, I rotated the piston in like you are suppose to do. After, the e-brake did not engage like you are saying. I remember being told that these self adjust by pulling repeatedly up and down on the e-brake handle. Sure enough, after a few times, it started to stiffen up. Have you done that?
Their is also a procedure to adjust the parking brake. Like mentioned earlier, you have to remove the back of the center console to get to the adjustment nut. According to the manual, you should raise back of vehicle to get the wheels off the ground, pull brake one click, then tighten nut until brakes just start to drag. Release brake to make sure brakes no longer drag. So you may just need to do a slight adjustment.Yes I did and it stiffened up and applies the rear brakes and stops the car from rolling but doesn't lock up the rear tires. They aren't grabbing tight enough.
I had a chance to replace my front pads this morning and also removed both rear tires to recheck both cables just to make sure everything was connected and working when the brake lever is pulled and engaged. So when I first changed the rear brakes and engaged the parking brake I could turn the rear tires by hand. Now the lever clicks with resistance and I can turn the rear tires but with force because the pads are grabbing now but when engaged fully I can get the car rolling when in drive or reverse. I didn't remove the caliper and align the rear pads with the piston yet but I did remove the plastic piece behind the console in the back seat and can see 2 cables and lifted the flap of carpet that is over the cables and there is no adjustment nut there at all.:dunno:Their is also a procedure to adjust the parking brake. Like mentioned earlier, you have to remove the back of the center console to get to the adjustment nut. According to the manual, you should raise back of vehicle to get the wheels off the ground, pull brake one click, then tighten nut until brakes just start to drag. Release brake to make sure brakes no longer drag. So you may just need to do a slight adjustment.
Why wouldn't you check the piston/pad alignment if you went as far as removing the rear tires? :dunno:I had a chance to replace my front pads this morning and also removed both rear tires to recheck both cables just to make sure everything was connected and working when the brake lever is pulled and engaged. So when I first changed the rear brakes and engaged the parking brake I could turn the rear tires by hand. Now the lever clicks with resistance and I can turn the rear tires but with force because the pads are grabbing now but when engaged fully I can get the car rolling when in drive or reverse. I didn't remove the caliper and align the rear pads with the piston yet but I did remove the plastic piece behind the console in the back seat and can see 2 cables and lifted the flap of carpet that is over the cables and there is no adjustment nut there at all.:dunno:
The truth INSANITY really :wave:Why wouldn't you check the piston/pad alignment if you went as far as removing the rear tires? :dunno:
Thanks for the link :thmsup:Get the manual for vehicle, you can DL off internet "
08-10 honda accord sm.pdf"
You will see parking brake is adjusted from that rear panel , there is a nut were the 2 cables come together .
here a link (hope its ok posting this ) .
http://www.4shared.com/office/_RuD0YOSce/08-10_honda_accord_sm.html
your going to have to remove the 2 slider bolts to check pads and piston are in right alignment .
