I'm trying to figure out an odd steering issue. It's difficult to explain, but one thing I can explain is that it doesn't want to recenter. In other words, you have to recenter it yourself after a turn to go straight. The problem is more severe in slower speeds and smaller turns. If you accelerate fast after a sharp turn, the wheel will return, but slowly and not all the way. And on small steering adjustments, the steering just sticks to wherever you turned it to. This is what I'm ruling out so far unless my thinking is mistaken:
1. I really doubt it's an alignment issue since I got one today and even before the alignment it didn't pull left or right. Besides, if I'm not mistaken, the steering returning to center is more of a castor issue which I'm not sure can be adjusted.
2. I don't believe it has anything to do with the power steering. I changed the power steering fluid since it was disgusting and way overdue for a change. There is noticeably less effort needed to move the steering wheel, but the issue remains similar to before. I might give it another go at it since maybe not all the old fluid was removed. I did use honda specific fluid.
I will jack up the car and see if there's any play. The only things left I can think of are:
1. Worn ball joints. However, the car doesn't vibrate and it doesn't wander too much. Or at least it seems this way.
2. Worn/bent steering rack. Not sure how to check this.
Sorry if I rambled too much. I'm just trying to paint a good picture. Does anyone have any idea what it might be? What else should I look for? Thanks in advance.
