Having owned three Honda Accords in the past 30 years I am on the hunt for a new one and looking for the version that will be the quietest and smoothest and most refined driving experience. Mindful that the answer to my question may be subjective, what are your experiences on the EXL with the 1.5 turbo, the touring with the 2.0 turbo, and the hybrid engine?
Again, my aim is to purchase a vehicle that will be as quiet and refined as possible. Thanks!
My apologies to the moderators, I accidentally posted this at first in the Hybrid section but would like it to be in this main section. Thanks.
You are asking a few different things. First off, the best advice would be to tell you to test drive the different options that you've mentioned and see which one is the best one for you.
All three engines are pretty smooth- but it is likely going to come down to your driving style. The 2.0t obviously has the most power of the three- so in most situations you probably won't be pushing that engine as hard as you would if you got the 1.5t engine. The CVT used with the 1.5t is a smooth transmission, but not everyone likes its sound or dullness. The 10-speed automatic that you get with the 2.0t engine shifts a lot- but generally it is pretty smooth too. In some cases, the power of the 2.0t can make it hard to accelerate smoothly when the roads are wet or slippery. It's really easy to spin the front tires if you push too hard on the accelerator from a stop. The hybrid is very smooth as well and it's performance is in between the 1.5t and 2.0t engines- with the added bonus of getting pretty awesome mpg.
One thing to consider is that for the 2021 model year, the 2.0t motor is only available in the Sport and Touring trim levels- which means that you also have to deal with the 19" wheels and tires that come with those trims. Those 19" wheels look great- but they will ride much more harshly than the 17" wheels that come on LX & EX-L trims. The 1.5t Sport and Sport SE trims also have the 19" wheels. In the case of those 19" wheels, be sure that you 'try before you buy'. Also keep in mind that the Hybrid Touring trim also comes with the 19" wheels for 2021. The 19" wheel/tire combo can be loud on the freeway and less-than-smooth surfaces. Some people argue that it isn't bad... but I noticed that there was a lot of road noise during the test drive as soon as I got the car up to about 55mph. The 17" tire option isn't as bad- but as the posters above said, the current generation Accord is not known for having low amounts of tire noise- regardless of wheel/tire option you get.
Also keep in mind that even if you do get an Accord with the 19" wheels/tires, it is possible to swap them out for the 17" wheel/tire combo. There always seems to be a demand for the 19" wheels online either through Craigslist, Facebook Marketplace, or even here through the classified forum. I'd imagine if you posted an ad there saying that you want to swap tires with someone, you'd find people that are interested.
Again- the best advice is to test drive the trims that you are interested in to help narrow down your choices.
