I was wondering how to remove the front license plates, when I got them from the dealer they were already drilled in. Anyone know the proper way to remove and fill the holes?
True, the 8th gen shouldn't have any drilled holes, but the sad truth is, some dealerships will. Even with factory instructions not to drill, some will take the time and effort to drill in the middle of the plate mount where there's an indentation and use a screw to help secure the plate mount, when it's not needed.You shouldn't have to bondo anything. At least not on an 2010. The bolt holes are hidden underneath. (same with 7th gen)
I took mine off in about 1 minute. Looks much better I think.
But yeah, if your local laws require a front plate, I'd leave it be.
Since the license plate bracket bolts on from under the bumper, if the dealer drilled holes into your's, I would demand they replace your bumper cover.I was wondering how to remove the front license plates, when I got them from the dealer they were already drilled in. Anyone know the proper way to remove and fill the holes?
Take your car back to the dealer and have them put a new bumper on your car!! Why are they drilling holes into the bumper of your new car? Is that really the only way to attach a front license plate? That's a bunch of B.S. if it is!!:thumbsdowI was wondering how to remove the front license plates, when I got them from the dealer they were already drilled in. Anyone know the proper way to remove and fill the holes?
Ummmm..... I think you would be "demanding" as such forever! No matter how petulant you got, I doubt there is a dealer in America who would replace the bumper cover in this situation. But one can always try, eh? ;-)Since the license plate bracket bolts on from under the bumper, if the dealer drilled holes into your's, I would demand they replace your bumper cover.
I guarantee you that if you drive a vehicle home from a reputable dealer and noticed that they butchered your bumper, they would be replacing it at no cost to you.Ummmm..... I think you would be "demanding" as such forever! No matter how petulant you got, I doubt there is a dealer in America who would replace the bumper cover in this situation. But one can always try, eh? ;-)
Just ONE hole?i have a hole drilled into mine.
By not installing the license plate? :winkI'm installing a license plate delete kit.
Why? Given what you said below:what i mean is this the best way to go
STO N SHO quick release front license plate bracket
Do you not plan to keep the plate on the car at all times?i know here in NJ they will pull u over each and every time so i just want a show n go type deal
