I replaced the distributor.
A few hints for someone who's replacing it:
-- It will leak some oil, be prepared.
-- Disconnect the connectorrized wires to it first (not spark plug wires). Press the connector button/ tap, to disconnect or connect the new one.
-- Remove the cap to know about were the rotor is. Lay it aside with the spark plug wire still connected.
-- There are two large bolts to remove.
-- Remove the cap on the new distributor, position it like the old one just removed.
-- Once removed, clean hole were it was. apply oil in the hole, and on the new distributor shaft o-ring.
-- Install the new distrib, if it dont go in, the cogs are hitting. It can only go in two ways: Correctly or 180-degrees out - Correctly, just slides in, incorrectly, almost fits, but only with force. So, rotate it till it fits.
-- There is some play for +/-1 degree or so of timing (used SG2 live data timing).
-- Set the old cap with the spark plug wire in the same orientation, on top of the newly installed distributor - Reinstall the spark plug wires one at a time, in the same location.
It obvious why the leaking oil kills the distributor (eventually), the pick up coil is in line with the leaking oil from off the shaft. Engineer: It should be moved, so that it dont leak on to it...
