After 271k miles, both the factory upper ball joints in my '08 Accord have a good deal of play and need replacement. Apparently aftermarket ball joints are to be avoided, so I plan to go OEM. But Honda appears to only sell the entire upper control arm, which on HondaPartsNow is $350!
Upper control arms are $35 a side at my local junkyard - after making sure the ball joint has no play I could replace the boots and grease. It'd be an improvement over what's on the car currently but I'm not sure it's a good idea long-term. Maybe someone's tried this?
It would be great if there was a way to get just the upper ball joint. Maybe the same ball joint was used on another model? Or maybe the OEM isn't actually Honda, and sells under their own name (in a similar manner to Idemitsu ATF)?
Has anyone found a way to source the OEM upper ball joint for an 8th gen without shelling out $350 per side?
