1 - 16 of 16 Posts
Tom-Accord
Hello,
I have a 2024 Accord with 300 miles on it. The weather has just started to turn cold and I've noticed a sweet smell coming from the heater supply. The intensity of the odor comes and goes and oddly, the smell from the driver side, right hand dash vent has the strongest smell. It is not really detectable in the other 3 dash vents. You can also detect the smell in the defroster mode. A Honda dealer ran a 30 minute/16 psi pressure test on the coolant system and detected no issues. They also used a flexible scope to inspect the heater core with no leaks found. The next step would be removing the dashboard to better inspect the heater core, but I would be liable for the cost unless a leak was found. I'm also hesitant deal with any potential downstream, out of warranty issues with removing/replacing the dashboard (rattles, electrical issues, etc.). The tech stated that additional customers have complained about this same issue - just posting this to determine if there are others out there with this symptom.
I also noticed a slight smell of antifreeze from the vents after taking delivery of my 24 Accord Touring Hybrid, so the dealer checked it and found no leaks. Happy to report that the smell went away completely over time and haven't had any related issue now over a year since delivery.
Even a tiny seepage will give you the smell you describe. I'd continue to monitor it and if it doesn't go away fairly soon. take it back to the dealership for a more thorough check.
- Jack
Discussion starter · #4 ·
Thanks audio.bill - that's comforting to know!
- Jack
Thanks jackpine, I am definitely planning to monitor the coolant level and look for any signs of leakage until it is resolved.
It is not uncommon for some initial "seepage" to occur as the new parts require a few thermal cycles to form a complete seal.
It only takes a couple of drops to create an odor and may take some time for the liquid to evaporate and the odor to dissappear.
I also have a 2024 Accord Ex 1.5 and noticed over the past couple of days, when using the heat, I have intermittent coolant odor. I have checked the coolant level at the radiator and reservoir, no loss of coolant. No leak on the interior or fogging of windows. Also confused by this issue
You may want to investigate the cabin filter. I was able to attribute the similar odor on my 2013 when purchased new.
I also notice a "sweet" smell whenever I replace that cabin filter. It's not that the filter is being contaminated with coolant since it's on the other side of the core, but when ever I remove the filter from it's protective bag a strong chemical smell permeates the cabin for a few weeks.
Worth looking into to allay your concern for a heater core leak.
1 - 16 of 16 Posts
