I have a 2008 Honda Accord EX-L (Auto) 4 cylinder with about 95,500 km. I bought the car used in August 2012 with about 93,000 km. The vehicle has the Honda Certified extended warranted for 6 years or 120,000km - which covers power train. I had a remote starter installed at Future Shop a couple of months ago, and all has been well.
Was on my way back to work after lunch and everything was fine. When I got into work and started to back my car in to a parking spot I noticed the "D" light was blinking on the dash. I put the car in Neutral, then Drive, and then Reverse again but no change. So I went ahead and parked the car and the "D" was still flashing.
I turned the car off and on again, and the "D" wasn't blinking anymore. All appeared normal on the dash. The only thing that I can remember happening before the "D" started blinking was driving in a puddle in the parking lot before I started backing the car in.
I've made an appointment at the dealership for tomorrow morning to diagnose the problem. While reading on this (and other) forums, I found that there are a number of possible causes:
1. Old fluid - which I admit I haven't replaced as the MM hasn't come on yet since I bought the car (it is at 60%).
2. Bad Pressure switches. Not sure if this applies to the V4, but have read a lot of occurrences with the V6 engines.
3. Wheel hub sensor.
4. Bad transmission
Does anyone know of any other ideas as to what may cause the problem? Or differing experience?
This was driving me a bit crazy so I went outside to check the transmission oil dip stick. The oil was below the low line, so I guess it needs some transmission oil. But what I am wondering is was the transmission oil that low when I bought the vehicle? Or, was it at a normal range and has been leaking gradually?
I guess we'll find out tomorrow. I think I'll also get them to do a drain and fill while it's there, since I don't know when the transmission fluid was last done on this vehicle.
But again, I would've thought buying from a Honda dealer would've meant they would have checked it.
4. Bad transmission
