There was no need to put the vehicle in PARK when you came to a stop and you just hit the power button. Vehicle went into park on power off.
Also when you just open the driver's door. And there are several other automatic shifts if you press a wrong button:
This button shifter is one reason I've procrastinated on replacing my 2018 Accord Hybrid.
You'll be more grateful when you need to shift it into neutral without battery power.
And that happens when....?
The huge turning radius/circle/whatever compounds the problem if you have to pull into a tight parking spot...you push buttons like a mofo whilst doing a 6 point turn.
Are you saying this is good or bad? I find that this car does the quickest, easiest N-point turns imaginable. More below.
My first vehicle that is not a stick shift, so the whole thing feels a bit weird, but I definitely prefer the lever to the push buttons. You don't have to look down to use the lever, much more intuitive.
You do have to push a release button, and count clicks. You are more likely to miss that way.
But you really don't have to look if it is inconvenient. For reverse, just slide your hand down the array. When a finger falls in a hole, that's the Reverse trigger and you are already pulling it. The Drive button is just as easy to find by feel, since it is large, has a raised rim, and
is always in the same place. The others you can look for, if the car doesn't choose them for you.
And the last thing is one you may be suspicious of, but it is OK. You don't need to come to a complete stop switching between Drive and Reverse. Motors work on the difference between the rotor's and stator's speeds. There is no torque converter to overwork. It is perfectly safe to switch into Drive when going -3 MPH, and the motor will "push" the speed to a positive value, instead of having to brake to a stop, change gears, and then accelerate. Just toggle the buttons.
It won't work above, I think, 5MPH. The car yells at you. But the fact that it does work below that speed means the system is designed to send the proper signal. It's no different than stomping on the gas pedal.
