So I had the valve cover off of my '14 2.4L yesterday to replace the gasket due to oil leaks. While I was in there, I noticed the timing chain seems rather slack.
(forgive the image quality, this is from a picture of the entire head. It never even dawned on me to take a photo directly of the chain itself...)
I'm able to push down and in on the chain and get it to mesh with the rest of those teeth on the front of the sprocket. Unfortunately I'm not too familiar with the tensioners on these cars, if they're hydraulic, if this is normal or not or really anything. 😄 I've seen in the past on here that others have had to replace their TCTs for grinding noises, but outside of a small handful of 0F starts in winter of last year when the oil got a little lower than I'd like, it never grinds at all.
Is this normal (chain slack w/ engine is off) or is this a TCT failure? Car has 110k miles on it. If it is the tensioner, can I just replace the tensioner or should I spring for a complete timing job and do the guides, new chain, VVT sprocket, etc considering the mileage? Thanks in advance!
