DIY: Installing an Injen Cold-Air Intake (EX-L V6)
How To: Install an Injen Cold-Air Intake on a 2008 or 2009 EX-L V6 Coupe.
This process is done to replace your OEM filter-box with an aftermarket high-performance cold-air intake ("CAI"). While these directions specifically discuss an Injen brand intake, I would imagine they can be duplicated to install almost any after-market CAI. Approx. Installation Time: Less than one hour. This is a simple "out with the old, in with the new" type installation. Things You'll Need:
Preparation You must remove your front bumper in order to properly complete this installation. Please see these instructions for bumper-removal. In addition, these instructions assume prior removal of stock air resonator box. If this part has not been previously removed, please follow these quick steps: 1. With the front bumper removed, use the 10mm Socket to remove the two bolts securing the resonator to the frame. 2. Firmly pull down and out to remove the air resonator box. This may require some aggressive pulling to accomplish. |
| Sponsored Links | ||
Advertisement | ||
Step 1: Removing the Battery and OEM Air Box
I suggest waiting at least 30 minutes after operating the car before attempting this installation. You will be reaching around the engine bay frequently and there is a very good chance you will burn yourself if working on a hot engine. The best time would be on a Saturday morning or something before you even take the car out. The Battery (Image 1):
With the battery out of the way, you are free to remove your OEM filter and air box (Image 2):
Image 2
Image 3
Step 1: Removing the Battery and OEM Air Box (con't)
Step 1.2: Removing the Lower Air Box
Lower Air-Box (Image 4.1)
Image 4.1 Image 4.2 You should now be able to completely remove the stock air-box. |
Step 2: Installing the Vibra-Mounts
Step 3: Installing the Primary Tube & Sleeve/Clamps
Step 3: Installing the Primary Tube & Clamp
The instructions that come with most intakes will suggest installing the clamp to the throttle body before attaching the primary tube. We found this order to be pointlessly difficult and instead attached the clamps to the tube first and then connected them to the throttle body. Primary Sleeve/Clamps - X3141 (Image 5)
Image 5
Step 4: Installing the Secondary Tube & Clamp
Secondary Sleeve/Clamps - X3144 (Image 7)
Image 7
Step 5: Throttle Body, Vacuum Hose & Mass Airflow Sensor
Throttle Body & Vacuum Hose(Image 8)
Image 8
You're done!! Congrats on your Cold-Air Intake. Please feel free to PM me with any questions regarding installation. If you give me advanced notice of your DIY, I can give you my number and be on-call to answer any questions you have during the process. Happy According! xxDaJackalxx
2008 EX-L Coupe V6 5AT - TW (*) P2R Ported Intake Runners (*) P2R Throttle Body Spacer (*) Injen CAI (*) Magnaflow CBE (*) Eibach Pro-Kit Performance Springs (~1.1'') (*) 15mm Ichiba Rear Wheel Spacers (*) 17mm TSX Rear Sway-Bar Swap (*) 5000k Xtreme HID Kit (*) Complete Interior & Exterior LED Conversion (*) HFP Aero-Spoiler Kit (*) Peripheral PXAMG iPOD Controller |
GOOD JOB! First Reply? I can use this for my I4 to remove the Air box. Thanks!
08 Accord Coupe Ex-L I4 Auto Mods: Nokya 2500k High Beam HID 6000k Low Beam Tinted 35% All Around Added OEM FOG Light Fujita Short Ram Intake P2R Throttle Body Spacer Megan EZ Coilover J-Power 3 arm-camber kit |
Yes, I believe the instructions for removing the intake resonator and OEM air-box are essentially the same.
Good job!
did you get a CEL???
Nice write-up Jackal...looks nice.
You guys must be getting really good at taking off that front bumper... haha I refused to take mine off for both installing my HIDs and my CAI... I always find a way around it (altho sometimes more difficult)
THROWDOWN PERFORMANCE Don't see the parts you are looking for... CONTACT US! 2008 Accord Coupe BBP EX-L V6 6spd :: BC RACING | EBC & TechnaFit BRAKES | P2R & Unorthodox Racing | | ULTRA RACING | SPC | Cipher Auto | M2 | Megan Racing | Short Shifter/Bushing/Clutch Line |
Thanks guys. Yeah, I can take off the bumper in like 5 minutes now that I've done it a dozen or so times (and not just on my car either).
AIJoker - No CEL after 500+ miles. All is well.
will doing any of the mods that have to do with performance, ie: exhaust or a cold air intake void your factory warranty? I want to start doing some upgrades but i'm weary about it for that reason only. Anyone know?
Black 09 EX-L V6 6MT HFP Bodykit all around Debadged Pinnacle Ceramic Tint- 15% Blacked Out Sunroof Blue LED conversion- map, dome, trunk lights |
Only if the problem is caused by your performance part.
If your truly concerned about it. I'd just get an exhaust, much less risk than an cold air intake. A dealership may try to give you shit for stuff, but they have to prove that if it was not for your aftermarket part, your car would be fine.
2009 Infiniti G37 Journey Sedan Silver on Black Leather 20% Tint all around Sold 5/4/10 2008 Alabaster Sliver V6 6-Speed W/Nav Injen CAI Magnaflow Exhaust 6000k HID's Stock 18"s Chrome Dipped Body Side Moldings Smart Shield 3M protective cover 20% Tint all around 2009 Acura TSX Switchblade Key Mobile 1 synthetic |
| Sponsored Links | |
Advertisement | |
