How hard is it to change the front rotors on a 2007 Accord LX V6?
Can anyone recommend decent rotors?
Thanks
Thanks
You MUST pull off the pads to even get the rotor off. depending on how bad your pads are it can ruin your new rotor fast.I'm not touching pads, so it should be easier than that even
Brembo Rotors decent?
\you dont need to bleed if you just push the piston back in with a c-clamp, just make sure you have enough fluid in the reservoir
Just use a plastic spoon and a paper cup (or something similar) and take a little fluid out before pushing the caliper in.\
I think I might have too much in the reservoir and it might over flow.
Happened last time, but didn't seem to affect anything. I've heard brake fluid is rather caustic.
