Having an issue with a parasitic battery drain on my 2014 accord EX-L Sedan (no nav). If I go about 16 or more hours without driving it, the battery will be dead.
Tested my battery and alternator...they are fine. Unplugged the negative terminal and left it overnight and it starts fine in that case.
Using my multimeter I found that my car is pulling 470 mAmps while it is turned off, but when I pull fuse 21 in the engine compartment fuse box, the Amps go all the way down to around 10 mAmps which I assume is normal. So that's the circuit in question...something that is controlled by engine compartment fuse 21 which is titled "Back Up".
When I pull that fuse with my car on, it gives me a warning in my dash board saying "Failed Forward Collision Warning System" so I am sure that is one of the things controlled by that fuse. The car won't start without that fuse in either.
I am looking all over to try and find what electrical components are controlled by that fuse, and any diagrams as to where those components are located. Can't seem to find that info anywhere. Can anyone help me figure out which systems are controlled by the "Back Up" #21 fuse? I'm happy to dig in and unplug them one by one to find the problem. But would rather not take my whole car apart!
Thanks!
Thanks!
