Changing the brake caliper, is it easy? straightforward? I can't seem to find any good instructions in my searches.
Background: 4.5 months ago, I changed all 4 rotors and pads. At the time, I noticed the rear left caliper boot or "dust cover" for the guide pin had a hole in it. I figured I would search for some sort of caliper hardware kit, and change within 6 months. Well, 10K miles later, that brake pad is dragging pretty bad, with the rotor getting all chewed up. So I think I'll have to either replace the hardware kit, or just change the caliper itself, if its too late.
Lastly, is it okay to replace just one caliper and pad set on one wheel, or should both sides be done at the same time? And should I buy an unloaded, semi-loaded, or loaded caliper?
