hey guys does anyone know the best fuel injector cleaner that i could use for my 07 accord and how would i go about actually performing the cleaning im kinda new to cars so any help would b appreciated
What 'problem' exactly?I had this problem not to long ago. ....
Clogged up fuel injector systemWhat 'problem' exactly?
i used to be a Shell V Power only guy down from Mobil since Mobil gas for some reason is always THE most expensive gas out thereI think if you use "top tier" gas (Chevron with the techron in it), you don't need any extra additives.
$6 off, it's still a waste of $11 IMO. I used to pour a bottle of Techron in once a year or so. I haven't used any in at least 5 years, and the engine still runs just as smooth. I buy the same brand of gas (Texaco), from the same station every time, and even with the 10% ethanol, she purrs like a kitten. I actually tried gas with no ethanol for a couple tanks, just to see what the difference would be. I went back to the Texaco. The engine seems to like it, ethanol or not.So has anyone tried/heard of this?
CRC 1-Tank Power Renew® Complete Fuel System Cleanup, Gasoline, 15 oz. 05815: Advance Auto Parts
Reason I ask is I have a $6 off coupon for it from AAP
So Honda, and all those other car companies are telling us to use "top tier" gas for nothing? Regardless, I've found a gas that works well with my engine, and I'm sticking with it. You can burn a gallon of gas driving around town looking for the $0.02 cheaper gas if you like.the thing about "additives" is that a company can literally drop one eye dropper full of an additive into a whole 18 wheel fuel tanker and "legally" state it has that additive
I don't see how this could be true. You are still getting the same volume of gas per dollar. And the gas under ground is not going to fluctuate in temperature nearly as much as the air or ground.Fill up at the coldest time of the day. Molecules are more compact and you get more bang for your buck.
Myth. Underground storage tank temperatures are very consistent year-round. It makes no difference what time of day you fill up.Fill up at the coldest time of the day. Molecules are more compact and you get more bang for your buck.
