Stick your head under the driver side dash and look on the side behind the fuse box area.
There should be 3 rubber grommets. I think depending on which model you have, there should be 2 that are unused.
Pop one out, push the wire through and that will lead to the fender area.
Remove some clips in the fender area (these break easily so you might just buy some replacement ones ahead of time) enough to get in there. This is easier if you jack the car up on the driver side, but its still doable without doing that. Just turn your wheel all the way to the left if you're not going to jack it up, but its still a PITA.
Reach way up, grab the power wire you fed into that area and continue feeding the wire up in the engine bay.
There's a black plastic cover on the driver side edge (if you're looking in your engine bay, its all the way to the right side). This is where your wire is going to pop out.
Make sure to put a grommet around the wire where it passes through to the fender area so the metal doesn't damage the wire over time. You can replace the stock factory grommet with one that fits your wire gauge or cut a hole in the factory one and feed the wire through, then run a bead of silicone around the wire.
Its best practice to loom the power cable from your battery connection to where it enters in the fender area.
