1 - 7 of 7 Posts
Ignignot
Whats the trick to installing the speed sensor so the car doesnt destroy it? Ive gone through 3 since having the transmission rebuilt. I am using the spacer (item 12) in the diagram but its still too close to 2nd gear and is getting chewed up. Thinking im going to make a thin washer out of an old credit card for the next try.
Discussion starter · #7 ·
Your transmission is modified, right? Are you still using the original 2nd gear?
Otherwise just grab some crush washers or something and make a spacer. It might take some fiddling but the speed sensor doesn't need to be super close to the gear?
Yeah its still the original 2nd gear. Its actually a really perfect ratio for digging out of "slow" corners with the tsx motor letting us rev to 7200rpm. Im gonna fiddle with spacers. Thanks for the advice
1 - 7 of 7 Posts
