I don't want to pay double to replace my engine air filer on my 2014 4DR Accord V6 so I would like to do it myself. I've looked everywhere online and I can't find anything specific to my car. Does anyone know where I can find some instructions?
I don't think you looked "everywhere"I don't want to pay double to replace my engine air filer on my 2014 4DR Accord V6 so I would like to do it myself. I've looked everywhere online and I can't find anything specific to my car. Does anyone know where I can find some instructions?
Haha thanks
Sweet!! That was easy. Cant believe the dealer wants $35 for that.It's easy , just unlatch 2 metal clips that holds the airbox chamber together and lift up the upper part to expose the filter. Drop the new one in and clip the cover in place.
+1 I'm paranoid about messing up my transmission :|If you believe in yourself, you can do anything!
Seriously though, before going to a mechanic or dealership over little stuff like this, look it up and see if you can do it yourself. Not just to save money, but the more you work on your car, the more you learn and the more you can handle situations when they arise. Self-sufficiency with cars is a rare quality in people nowadays, haha.
Now I just need to get up the courage to get under my car and do a drain and fill for my transmission fluid...
Thanks. Yeah I've had transmission nightmares with my 98 accord.Now I just need to get up the courage to get under my car and do a drain and fill for my transmission fluid...
What's the dealer charge rate now? $100 an hour?Sweet!! That was easy. Cant believe the dealer wants $35 for that.
Oh please! Give me a break.What's the dealer charge rate now? $100 an hour?
You have to appreciate when you bring your car in, even for something as simple as an air filter change, your car has to be entered into the service record system by the service advisor, a mechanic is then allocated to go find your car in the parking lot, drives into the shop, replaces the air filter, do a quick check to make sure everything is done right, then your car may get a quick wash before it is driven to the parking lot and parked.
The service advisor will then have to process your payment when you come in to pay for the work performed.
How much do you think all that should cost? $35 labor charge isn't all that unreasonable.
What do you think is a reasonable price?Oh please! Give me a break.
These cars are fairly simple to do. You refill until it starts to drip, stick plug back in once the dripping stops. It's critical the car is on a level surface. I place a drive on ramp at each wheel after jacking each end of the car up. I suppose jack stands work too, I just don't have 2 matching pairs.+1 I'm paranoid about messing up my transmission :|
15 Minutes? More like 5 minutes of labor. And you can buy the filter online for about $12. 5 minutes of labor at $105/hour is about $9 plus the $12 for the filter is $21.I was quoted $85 to change the cabin air filter...that's not reasonable...for a 15 minute job
I had to remove the glove box, kick panel and the trim panel between the dashboard and the passenger side door just to get to my cabin air filters in my '99 sedan.Cabin air filters vary, some are easily accessible, others require glove box to be dropped.
On the infiniti it's more of a pain, there are several hard to reach screws that have to be removed & several electrical connectors to undo (along with a few trim pieces). Still, 15-20 min job at most after doing it once or twice.
Here in the problem, everybody expects a break. :grinOh please! Give me a break.
^ Exactly. The fact that some of you guys are shocked by this is kinda scary.^^Likely a minimum shop charge of a half hour, + shop supplies. So that's $52.50 + 12 + 7.5 + tax = ~72. So they round it off to a flat rate of $85![]()
