Does anyone know what the torque specs are for the calliper bolts and calliper mounting bolts?
Thanks.
Thanks.
Okay, im sorry i took so long to get back to you.Does anyone know what the torque specs are for the caliper bolts and caliper mounting bolts?
Thanks.
Just snug bud. No need to muscle it in. Just get it snug and you’re good to go.2016 Acoord EXL coupe. Does anyone know the torque specs? Thanks.
Thanks.Here you go
One trick I learned on my Odyssey brake job which works for the fronts at least is to turn the wheel all the way to the outside - then the whole caliper assembly is angling out and you can get any length torque wrench on it (or breaker bar to loosen them at the start). Obviously doesn't work on the rears since those don't turn, but the rear assembly is smaller and the torque specs are lower. I think I still was able to fit in a 3/8 torque wrench in the wheel well there, on the Odyssey. Haven't taken off the caliper bracket on the rear of my Accord yet but may be doing so soon so I can file it down and make sure the pads are nice and freeThis is a tight space to work. Does anyone have recommendations for a compact torque wrench? My 18" might be a bit cumbersome. Up until now, the only thing I've used the wrench for are lug nuts, but all my life I've only hand tightened bolts with >99% success rate (no broken plugs or lugs, and no losses). the only time hand tightening has failed me was with one of my valve cover bolts on my 1989 Civic, which i was able to replace as a 18 year old with no "good" tools.
and those pictures are just for the frontsThanks.
80 lbft on the bracket bolts and 37 on the sliding pin bolts.
I will prob use a torque wrench for the bracket bolts. Usually when I open the sliding pin bolts to check brake pads I just snug them back by hand. I'm not that experienced as a wrencher so not sure how close I am getting to 37, but I figure my arm can generate 37 pounds of force
Rear bracket is is 80lbft accord to Honda. Rear caliper bolts are 17lbft, so I'd tighten those by hand.and those pictures are just for the fronts
I think the rear is lower torque on the caliper brackets
There is another thread on here where the guy said they were both 80, but then he only showed the picture for the fronts. I would like to confirm on the rears as on my Odyssey they are significantly lower (smaller caliper and caliper bracket)
EDIT: It appears that rear caliper bracket torque is 41? Is this right?
