The other day I saw a video on youtube, this guy used and aerosolized can of sea foam to remove the built up carbon on his pistons.
Its an aerosol can that comes with a little spray tube, kind of like wd-40. apparently you just slide the tube under the factory intake tube and then clamp it back shut so its sealed. while the engine is running he sprays the entire can into the intake system.
The car began to smoke a lot a lot, he claims this is the carbon burning off. He shows a before and after with a camera going through the port for the sparkplugs, which showed a fair amount removed. I'm just looking at preventative measures for my own car and thought this might help keep things running smooth. Does anyone have any input on the subject?
