What can I expect from doing a valve adjustment on my v6 engine with 112k?
Increased performance?
wondering if it's worth the trouble
I don't see the connection between the timing belt job, and the valve adjustment?:dunno: I didn't remove any of the same parts doing the two jobs. For a rookie, shade-tree guy like myself, those two jobs are too much for one weekend, much less the same day. I did the timing belt, and valve adjustments two months apart.I would do it. You could burn the exhaust valves if they get too tight. Just do it for the peace of mind. Especially if your doing the timing belt.
You don't have to loosen the valve cover on my J30 engine, or did I miss a step in the service manual? The upper covers came off without any trouble. The timing belt kit I bought had the valve cover gaskets included, and it made me wonder why. I know the timing belt, and valve adjustments are due at the same mileage, but I wouldn't try to do both jobs the same day, especially if it was my first time doing them.The only connection between timing belt change and valve adjustment is the valve cover which has to be loosened in order to remove the upper timing belt cover. Once loosened the valve cover could leak, so its better to remove it and change the gasket especially if its 10+ years old. If you have the cover off, you might as well check the valve clearance and adjust if needed.
Had mine (i4) done at the dealer. Didn't see a difference in sound or anything. The only thing I noticed was that they cleaned the engine.It's not like your engine will die, if you don't adjust the valves. The intake valves do tend to loosen over time, and the exhaust valves tighten. If your intake valves are loose, the engine will sound quieter after the valves are adjusted. I did the valve adjustment myself at 94k miles. If I had to pay someone else to do it, I would probably still be waiting. The fact that the exhaust valves tighten over time means they could possibly tighten enough to burn a valve, but the chances of that happening, before 200k miles, is slim and none.
Always good to hear your sage take on areas of interest to this sailor.The exhaust valve adjustment gets tighter because the valve and seats wear down due to the hot exhaust. This makes the valves sit higher in the head reducing the clearance. As long as the wear is even they will continue to seal and no valve grinding or replacement is needed.
intake valves stay nice and cool while exhaust valves get hot and wear? Not sure what kind of engine you are working on but both valves are in the combustion chamber and exposed to the same heat. To my knowledge they are both made of the same material. Could you possible explain a little further? Im not sure I see your point...The mechanical valve adjusters never change settings. The valves only need to be readjusted to compensate for wear in the valve train. The exhaust valve adjustment gets tighter because the valve and seats wear down due to the hot exhaust. This makes the valves sit higher in the head reducing the clearance. As long as the wear is even they will continue to seal and no valve grinding or replacement is needed.
The intake valves wear very little since they stay nice and cool. They get looser due to the wear on the cam and rockers.
Would it be a fair statement that exhaust valve wear (uneven) would be reflected in less fuel economy? Any other symptoms you can think of appreciated big time...............
(Just like your take on Iridium spark plug longevity: thanks again)
all the best, ez....
